KB84162
Published: October 31, 2014
Configurator crashes after re-configuring Discrete On or Off text
Versions affected: R9.4a and R9.4b
Problem is fixed in version: R9.4c
Configurator crashes after editing either of the Discrete On or Off text fields on the Dynamic Attribute-Text In from Control Engine dialog box and then closing the project. The crash might occur while you are doing anything else in Configurator. Or, it might happen when closing the project.
Here's how you get to the Discrete On and Off text fields:
  1. Select text (typically #) and choose Edit > Edit Dynamic Attributes (or just double-click the text).
  2. Select Text In from Control Engine, and then click Edit.
  3. Select Setup By: Discrete, and then edit the Discrete On and Off text fields.
