KB84142
Published: December 10, 2014
PAC Control: Send Email command through Gmail returns an error
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: All versions
If you use the PAC Control "Send Email" command with a Gmail account, it returns an error (usually -43 or -2104).
New Gmail security standards as of late October 2014 won't let the email go through by default.
Log into your Gmail account and enable "less secure apps." Gmail warns that this "increases your chances of unauthorized account access."
More information from Gmail:
https://support.google.com/accounts/answer/6010255
