KB84118
Published: November 10, 2014
SNAP-AIR400K-8: Temperature reading may go to -32768 during a rapid change in temperature
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
Problem affects versions: Firmware R9.4a and lower
If you are using a SNAP-AIR400K-8 and have configured a channel for Temperature, you may briefly see a value of -32768 when the temperature changes rapidly, for example from 120 degrees F to 32 degrees F. The reading returns to the correct value after about 6 seconds.
