KB84111
Published: October 28, 2014
Historic Logs dialog allows multiple selections
Problem was introduced in version: R9.4a
Problem is fixed in version: R9.4c
The PAC Display Configurator Historic Logs dialog (Configure > Historic Data Log) allows multiple Historic Logs to be selected at the same time, but it should only allow one item to be selected. When you select an item, the previously selected item should automatically be de-selected by PAC Display, but it is not.
