KB84102
Published: November 7, 2014
SNAP PAC controller or brain resets when streaming over WLAN interface
SNAP-PAC-EB1-W
SNAP-PAC-EB2-W
Problem affects versions: Firmware R8.5a through R9.4a
If you're using a SNAP PAC R-series controller or a SNAP PAC EB-series brain to stream data wirelessly, when you enable streaming, the controller or brain resets. The time it takes to reset is dependent on the Stream settings. The reset could happen immediately or take a few minutes to occur.
Stream over a wired interface.
