KB84085
Published: November 5, 2014
PAC Control Unpack String command may fail without error if source string data is too short
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.4a
When you use the PAC Control command Unpack String, if the source string data is too short for the specified parameters, the command will not work as expected, and you will not receive an error.
Before calling this command, verify that the source string contains enough data for the Start Index and Width parameters.
