KB84051
Published: September 26, 2014
SNAP PAC brain continuously resets on powerup
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
SNAP-PAC-SB1
SNAP-PAC-SB2
Problem affects versions: Firmware R9.4a
After restoring to factory defaults using the reset button, assigning an IP address, and storing configuration to flash, when you restart the SNAP PAC brain, it continuously resets.
