KB84020
Published: September 26, 2014
Controller locks up when the value of a serial PID is changed while inspecting the PID in PAC Control in Debug mode
SNAP-PAC-S1-FM
Version affected: R9.4a
Attempting to change any value of a PID on a serial or Ethernet brain via the PAC Control debugger causes the controller's host port to become unresponsive. Once this has occurred, charts attempting to communicate with any I/O unit on that same serial port as the I/O unit with the PID loop also become unresponsive. The controller must be rebooted.
