KB84013
Published: September 26, 2014
E1 and E2 respond more slowly than B1 and B2 to Optomux commands
E1
E2
Problem affects versions: Firmware R1.1d and lower
Problem is fixed in version: R1.1e
E1 and E2 brain boards may take longer to respond to Optomux commands than the B1 and B2 brain boards they replace.
For example, the E2 responds to "L" and "S" commands in 3 to 11 milliseconds, but the B2 responds to the same commands within 3 ms.
The E1 responds to the "J" command in 4 to 11 milliseconds, but the B1 responds to the same command within 2 ms.
