KB84006
Published: November 3, 2014
groov View for iOS: Removing passcode option from connection does not clear passcode
Problem affects versions: R2.34 and lower
When you set up a connection to require a passcode, the first time the connection is attempted, you are asked to set a passcode and then to confirm it.
If you remove the passcode requirement later, you have to enter the passcode to remove it. However, if you then decide again to enable the passcode option, you are asked for the old passcode instead of being asked to set and confirm a new passcode.
