KB83999
Published: November 3, 2014
More than the maximum 31 host connections may cause control engine to become unresponsive
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R9.4a and lower
If you try to open additional host connections after the maximum 31 connections are already open, the controller may eventually become unresponsive and unable to make any Ethernet connection using any protocol. A power cycle is required to recover.
Don't open more than the maximum 31 host tasks. If the problem occurs, cycle power or reset the controller.
