KB83998
Published: November 3, 2014
SNAP PAC controller with microSD card inserted may fail to configure I/O on a restarted I/O unit
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R9.4a and lower
When a PAC controller has a microSD or microSDHC card inserted on powerup, if an I/O unit controlled by that PAC is turned off and then turned on again, the controller fails to configure its I/O.
