KB83985
Published: October 8, 2015
If a window is open in groov Build and in another tab the same user logs out, the window persists.
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: groov App, all versions
If you have two tabs open and you are logged in as the same user in each tab, and in one of the tabs you have a window open (such as manage accounts or tag browser), when you log out in the other tab, the window will still be open and usable in the first tab.
If you log out of one groov tab, close all open windows in any other groov tabs.
