KB83959
Published: July 30, 2014
Backing up a groov project before saving prompts window to save all changes but does not back up
GROOV-AR1
GROOV-SVR-WIN
GROOV-AR1-SNAP
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.1d and newer
In groov Build, if you've made a change but not saved your project, and you choose File > Backup Project to Computer, a dialog box asks if you want to "save all changes" before proceeding. When you click Yes, the project is not backed up.
Before trying to back up your project, make sure you save all changes.
