KB83940
Published: October 23, 2014
PAC Display Runtime memory usage increases with historic logs
Versions affected: All versions earlier than R9.4a
Problem is fixed in version: R9.4a
Memory usage may ramp up continually when running PAC Display Runtime with a project that has historic logs logging integer and/or float tables. The memory usage will continue to increase until the system runs out of memory or PAC Display crashes.
