KB83924
Published: October 15, 2014
In iOS groov View, editing a non-active connection returns to the active web page
Version affected: 2.31
Problem is fixed in version: 2.32
With an active connection, if you select Edit from a non-active connection you are returned to the active connection page. If you swipe back to the main list, the non-active connection is now green even though it is not the active connection.
