KB83921
Published: December 1, 2015
PAC Display: Combo box retains focus at runtime
If you click a combo box in PAC Display Runtime, the combo box retains focus (that is, it will respond to your keystrokes) even if you click elsewhere in the HMI.
For example, if you click a combo box, and then you click inside a text box in the HMI and press the down arrow key, the combo box will highlight the next item down in its list because it has retained focus.
