KB83912
Published: August 28, 2014
E2 brain incorrectly implements Set Temperature Probe Type command (k)
E2
Problem affects versions: Firmware R1.1d and lower
Problem is fixed in version: R1.1e
If you use a probe type format of two to four digits, the k command returns an A as if it had worked properly. However, when you send the Read Temperature command, the results are ????, showing that the channel was not properly configured.
Use a single ASCII hex character to specify probe type in the data field for command 'k'.
