KB83888
Published: June 27, 2014
Controller may return a "Dictionary Full" error when memory is low
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.3e and lower
Problem is fixed in version: Firmware R9.4a
When downloading a strategy, you see a "Dictionary Full" error, implying that there are no more entries available for the dictionary; but in reality, the strategy has consumed the available memory.
Since the correct error is that the strategy has consumed the available memory, follow the usual steps for reducing the strategy's memory footprint: use smaller tables, shorter strings, etc.
