KB83881
Published: August 25, 2014
Analog module point configuration not stored to flash correctly with I/O Unit Import/Copy Utility
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
SNAP-PAC-SB1
SNAP-PAC-SB2
G4EB2
Problem affects versions: Firmware R7.2a through R9.4a
This issue affects SNAP PAC brains and rack-mounted controllers with analog modules that have more than four points. Point configuration on these modules may not be properly stored to flash memory when you are using the PAC Manager I/O Unit Import/Copy Utility to copy the configuration to another I/O unit.
On an 8-point analog module this issue affects points 6 and 7 (the last two points). On a 32-point analog module the issue affects points 6-15 and points 22-31.
Manually enter the point configuration for the second I/O unit using PAC Manager or PAC Control.
