KB83836
Published: May 14, 2014
Under certain conditions groov may fail to import a PAC Control strategy
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was introduced in version: groov App R1.0
Problem is fixed in version: R2.2a
When you're trying to import an idb.txt file from a PAC Control strategy into groov Build, the operation never finishes. The progress spinner continues to spin and the strategy is not imported.
Manually edit the idb.txt file and change the path to use a drive letter.
