KB83835
Published: October 20, 2014
Revision: 4.0
If incorrect syntax is used when referencing tables in OptoScript, the controller becomes unresponsive on the host port, or the controller resets, or a -16 Bus Error appears in the error queue
PAC Control Basic
PAC Control Professional
If you use incorrect syntax when referencing tables in OptoScript, the controller becomes unresponsive on the host port, or the controller resets, or a -16 Bus Error appears in the error queue.
Make sure to use square brackets when a command expects a table element, for example: stData[3]. Don't use square brackets when a command expects a table as opposed to a table element.
