KB83784
Published: September 9, 2014
groov may become inaccessible with a link-local connection when network interface settings are changed
Version affected: All versions
groov no longer responds after applying a new configuration to the second (ETH1) network interface.
If groov becomes unresponsive or inaccessible, use groov Find to see whether the link-local address has changed. If so, use the new address to access groov.
