KB83759
Published: September 15, 2014
groov View for Android app may crash when using the back button after a failed connection
Versions affected: R2.00 - R2.30
When you tap the back button in the groov View for Android app after groov fails to connect to a connection but prior to the "can't connect" message appears, the groov View for Android app may crash.
Wait for the "can't connect" message indicating the connection attempt has timed out (usually takes ~60 Sec); then tap the back button.
