KB83687
Published: June 2, 2014
Slider confirm prompt appears when continuous attribute is enabled
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.1 and lower
Problem is fixed in version: R2.2a
When choosing properties for a slider in groov Build, if you check Continual and then check Confirm, you will see a command prompt in groov View when the slider value is changed. (The command prompt should not appear when the Continual property has been enabled.)
Uncheck Confirm before checking the Continual property on a slider gadget.
