KB83686
Published: June 2, 2014
Slider and checkbox return to current value during confirm prompt
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.1 and lower
Problem is fixed in version: R2.2a
When you create a slider gadget in groov Build with the property Confirm, the slider's behavior in groov View is not as expected.
In groov View, if you click on the slider and drag it to a new value but then do not immediately click a button in the confirm prompt, the slider and check box return to the current value. If you then click a button in the confirm prompt, the slider's value remains unchanged.
In groov View, when you move a slider, click the Yes button in the confirm prompt within one second.
