KB83682
Published: June 25, 2014
OptoOPCServer high CPU usage
OptoOPCServer
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.4a
When PAC Display is configured to access the I/O directly from the I/O (as opposed to indirectly via the control engine), and there are no actual I/O tags to be scanned, CPU usage becomes very high about every 30 seconds for about 5 seconds.
