KB83665
Published: June 2, 2014
groov gadget text in Internet Explorer 11 does not stay within the gadget's window box boundry
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R1.0c through R2.0c
Problem is fixed in version: R2.2a
If you use Internet Explorer 11 for groov, in both groov Build and groov View a gadget with text greater than the limit of the gadget's window box will appear outside of the window boundaries.
If you use IE11 to build a groov interface, your intended design may not be displayed properly on groov View in other browsers.
Use another web browser instead of IE11. Firefox, Chrome, Safari, and IE10 can all be successfully used.
