KB83558
Published: July 1, 2014
Can't enter IP Address with 3 digits when configuring Event Message
PAC Manager
Versions affected: R9.3c and earlier
Problem is fixed in version: R9.4a
When using PAC Manager to create or edit a configuration file (File > Open or File > New), in the Memmap Copy section of the Configure Event Message dialog, the IP Address control will not allow 3 digits to be typed in.
This issue does not apply to Inspect mode (Tools > Inspect).
