KB83527
Published: June 25, 2014
Configuring trigger #2 on the Digital Events Expanded page doesn't stick
PAC Manager
Versions affected: R9.3c and earlier
Problem is fixed in version: R9.4a
In the Inspect window in PAC Manager, if you select Events > Digital Events Expanded and configure trigger #2 with something other than Scratch Pad Bits (e.g. Digital Point State), when you click Apply, the change isn't written correctly, so it appears that it did not get written at all.
In the Inspect window, select Other > Generic Read/Write to write directly to the memory map. For information on how to configure Opto 22 memory-mapped hardware, see form 1465, the OptoMMP Protocol Guide.
