KB83468
Published: June 4, 2014
Loading Tags dialog box stuck after changing user password and logging out
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.0c and lower
Problem is fixed in version: groov App R2.1a
After you set a new user password in groov Build, log out, and log back in, the "Loading Tags" dialog box appears stuck in the center of the groov View screen.
This issue applies to groov View pages that contain OPC-UA tags.
Press the Esc button, or close and re-open the browser.
