KB83307
Published: June 4, 2014
Error messages may not disappear after range problems have been fixed
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was discovered in version: groov App R2.0c
Problem is fixed in version: groov App R2.1a
In groov View, if you move a slider to a positive or negative value that is outside the valid range for that data type, yellow triangles appear on all gadgets with an error message that groov has lost connection to the controller.
This issue may also affect other gadgets.
When dealing with float variables in groov Build, be sure not to exceed the type's maximum or minimum capacity.
