KB83295
Published: September 9, 2014
I/O unit name change not allowed when only correcting upper/lower case
PAC Manager
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.4a
When editing an existing I/O unit name, if the only change you're making is to correct a typo related to upper/lower case (like changing e2 to E2), you'll see an error message: "This name already exists. Please enter a unique name for the I/O unit."
This issue occurs even if you haven't yet saved the file.
Just change the name to something unique (like E2x), click OK, and then modify it back to what you really wanted (like E2).
