KB83137
Published: September 9, 2014
SNAP-AIR400K-8 missing in EtherNet/IP Configurator
EIP_CONFIGURATOR
Problem affects versions: R3.0i and lower
Problem is fixed in version: R3.0j
In EtherNet/IP Configurator, the Add Module dialog box does not include the SNAP-AIR400K-8 module, so the module cannot be configured.
  1. Use PAC Manager to configure all points.
  2. Then use EtherNet/IP Configurator only to configure EtherNet/IP assemblies.
