KB83045
Published: November 24, 2015
PAC Control: Unable to delete a block that was referenced by multiple continue blocks
PAC Control Basic
PAC Control Professional
Problem was discovered in version: R9.3b
Sometimes when you delete a section of a PAC Control chart, a block that is the destination for multiple continue blocks becomes "orphaned." When this happens, PAC Control prevents you from deleting the destination block, even though all of the continue blocks that referenced it have been deleted.
