KB83014
Published: September 27, 2016
PAC Control should report a compile error if you pass in an incorrect parameter when the argument is a table
PAC Control Basic
PAC Control Professional
Versions affected: R9.3R through R9.5b
Problem is fixed in version: R9.5c
When a command or subroutine in an OptoScript block requires a table as its argument, PAC Control may incorrectly allow you to pass in an object that is not a table (for example, a table element). This issue typically causes a -95 error in the controller’s Message Queue when you run the strategy.
