KB82508
Published: August 29, 2014
With E2 brain, PAC Manager shows DA6 configuration offset by -5V
E2
Problem affects versions: Firmware R1.1d and lower
Problem is fixed in version: R1.1e
If you are using an E2 brain board and configure a DA6 in PAC Manager, the configured point will be offset by -5V from the actual output. For example, if the actual voltage measured across the terminals is -3V, PAC Manager will show -8V. The value shown in PAC Manager will be 5V less than the actual output value.
Add 5V to values received from the E2. (This issue affects reads only, not writes to the module.)
