KB82489
Published: August 20, 2020
PAC Control Find does not find OptoScript with non-standard capitalization
PAC Control Basic
PAC Control Professional
All versions prior to R10.3b
R10.3b
In PAC Control, if you use the Find tool (Edit > Find) to look for a command instruction, the Find tool will not find OptoScript instances where the instruction is written with non-standard capitalization. For example, if you search for the StopChart instruction, it will not find instances where the command is written as "stopchart" or "stopChart" or "Stopchart".
