KB82216
Published: April 1, 2016
PAC Control variables do not show up in the Strategy Tree when copied
PAC Control Basic
PAC Control Professional
Problem affects versions: All versions
In PAC Control, when you copy a block from a subroutine (or another strategy) into a chart, if the block contains a variable that didn't exist in the strategy before, the paste report indicates that the variable has been added. However, the variable does not appear in the Strategy Tree.
Save your strategy, close PAC Control, and reopen it.
