KB82165
Published: February 1, 2022
Modifying a subroutine parameter generates an incomplete or incorrect "report"
- PAC Control Basic
- PAC Control Professional
All versions prior to R10.4b
R10.4b
If you modify a parameter of a PAC Control subroutine that is already used in a strategy, when PAC Control validates the change, the message it displays may be missing the names of the charts that call the subroutine.
For example, if you modify a parameter to a subroutine called "Peer" that is called from the Powerup chart, when PAC Control validates the change, it does not list the Powerup chart under the "Calling charts:" section.
TITLE: Subroutine Files Modified or Not Found
DATE: 06/29/12 TIME: 09:52:00
________________________________________________________________________________
The following subroutines have had their parameter lists changed. Each instance must be inspected and possibly reconfigured.
C:\Opto22\OptoProjects\Peer.isb
Calling charts:
