KB81322
Published: September 9, 2014
Sending binary data in event message may produce unexpected output
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
G4EB2
G4D32EB2
G4D32EB2-UPG
OPTOEMU-SNR-3V
OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR2
Problem affects versions: Firmware R9.4a and lower
When using a binary plug-in in an Event Message, you may notice bad or unexpected output.
The smaller the plug-in, the more likely it is to occur. For example, &#x0A0D is more likely to result in strange output than &#x48480A0D4848. Another factor is the length of the part of the message following the plug-in, where a longer following message is more likely to show this issue.
