KB81203
Published: October 15, 2014
SET TIME DELAY command does not work with an E1 brain board
E1
Problem affects versions: Firmware R1.1d and lower
If you try to use the SET TIME DELAY Optomux command (command Z) on an E1 brain board, the command always returns an error of N05.
