SNAP-SCM-SSI
SNAP-SCM-SSI
$429.00 (USA and Canada only)
OBSOLETE SNAP SSI (Serial Synchronous Interface) Module
The SNAP-SCM-SSI module provides two individually isolated serial synchronous interface (SSI) inputs for acquiring data from linear or rotary transducers used in motion control.
The module can decode both binary and Gray Code, and is software configurable to set clock speed, frame length, delay time between data samples, and other parameters.
Part of the SNAP PAC System, the SNAP-SCM-SSI input module mounts on a SNAP PAC rack with other SNAP I/O modules to provide the mix of analog, digital, and serial I/O you need at any location. The mounting rack also holds an I/O processor, either a SNAP PAC brain or an  R-series programmable automation controller.
Unlike other SNAP serial modules, the SNAP-SCM-SSI can be used with either SNAP PAC Ethernet or serial-based brains (EBs and SBs). The module cannot be used with any legacy SNAP brain.
Use PAC Manager version 9.0 or newer to configure this module as well as other I/O modules on the same unit. See the SNAP SSI Module User's Guide for complete information on installing, configuring, and using the module.
Maximum SSI clock frequency
2.5 MHz
Channel-to-channel isolation
1500 VAC
Logic supply voltage
5.0 VDC
Logic supply current
200 mA DC
Compatible I/O processors
SNAP PAC R-series controllers and SNAP PAC EB or SB brains with firmware 8.5c or newer
Number of ports per module
2
Max. number of modules per rack
8
Max. data resolution
24 bits
Maximum cable length
500 feet at 200kHz using twisted-pair, 24-gauge shielded cable with an additional pair for common (three pairs total)
Operating temperature
-20 to 60 °C
Storage temperature
-30 to 85 °C
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Agency approvals
CE, RoHS, DFARS
SNAP SSI (Serial Synchronous Interface) Module Data Sheet
SNAP SSI (Serial Synchronous Interface) Module User's Guide
This guide provides instructions for installing, configuring, and using the SNAP SSI module.
Scaling and Linearization Example
A example strategy written in PAC Control Basic R8.2f that demonstrates how to scale and linearize values. This example strategy uses subroutines to perform most calculations.
