*** The SNAP-ENET-S64 is obsolete and no longer in production. ***
Instead, use a
SNAP-PAC-R2 controller/brain; it has all the same features plus additional power (and programmability, if you need it).
The SNAP Simple Ethernet I/O brain is a low-cost I/O and communications processor for high-density commercial and industrial applications on wired Ethernet networks.
The SNAP-ENET-S64 brain can be mounted on any SNAP PAC mounting rack along with SNAP I/O modules. It provides local intelligence for analog, simple digital, and tunneling serial capability.
NOTE: Not all SNAP I/O modules are compatible with this brain. See
Legacy and Current Product Comparison and Compatibility Charts to determine compatibility.
SNAP-ENET-S64 [Obsolete]
Power Requirements
5.0 VDC ± 0.1 VDC at 1.2 A maximum (does not include module power requirements)
Operating Temperature
0 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
Network Interface
IEEE 802.3 network, 10Base-T and 100Base-TX
Serial Port
RS-232 (for programming and diagnostics only)
Serial Data Rates
Default is 19,200 kBd; baud rate is soft-selectable from 2400 to 115,200 kBd.
100 meters with Category 5 or superior UTP.
Jumpers (Internal)
Boot to kernel/boot to loader
Reset to factory defaults
Agency Approvals |
CE, RoHS, DFARS; UKCA |
*** The SNAP-ENET-S64 is obsolete and no longer available. ***
Opto 22 suggests you consider SNAP-PAC-R2.
Opto 22 SNAP Simple I/O™ is a low-cost solution that offers Ethernet/TCP communications as well as analog, simple digital, and serial capability on the same mounting rack. Used for high-density commercial and industrial applications and for remote monitoring applications with high I/O point counts, a SNAP Simple I/O unit consists of a SNAP-ENET-S64 brain mounted on a SNAP M-series rack with standard SNAP I/O™ analog, digital, and serial modules.
This README file lists revision changes made to the SNAP Simple I/O firmware used in SNAP Simple I/O brains.
This README file lists revision changes made to the SNAP Ethernet I/O firmware used in the following SNAP Ethernet brains:
This README file lists revision changes made to the firmware used in SNAP PAC family controllers before Version 8.0a, the SNAP-LCE controller, and SNAP Ultimate, Ethernet, and Simple brains.
If you are using SNAP PAC controllers and SNAP PAC brains only, use Form 1704, PAC Manager User's Guide instead of this guide.
In addition to
groov I/O and the SNAP PAC System, the guide also covers Modbus/TCP communication with older Opto 22 Ethernet-based devices, including SNAP Ethernet, SNAP Simple, and SNAP Ultimate I/O; and E1 and E2 brain boards.
This guide is for programmers who are writing custom applications to communicate with Opto 22 memory-mapped devices. These devices include groov EPIC processors; groov RIO modules; SNAP PAC controllers and SNAP PAC EB and SB brains; G4EB2 brains; SNAP Ultimate, SNAP Ethernet, and SNAP Simple I/O; E1 and E2 brain boards, and SNAP-LCE controllers.
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
*** NOTE: These products are obsolete and no longer available. For new development, we recommend groov RIO and groov EPIC. ***
This guide shows you how to install, use, and troubleshoot I/O units that contain the following brains: SNAP-B3000-ENET, SNAP-ENET-S64, SNAP-UP1-M64, SNAP-UP1-ADS, SNAP-ENET-RTC, SNAP-ENET-D64, and SNAP-UP1-D64.
NOTE: This guide replaces previous individual user's guides for SNAP Ultimate I/O (form #1311) and SNAP Ethernet I/O (form #1112).
This document describes migration options for customers integrating the SNAP PAC System with older Opto 22 systems. It explains the SNAP PAC System's similarities and differences with earlier systems, defines legacy products, and shows how to mix old and new hardware.
This technical note shows you how to set offset and gain for Opto 22 analog input modules.
This download contains current firmware for the SNAP-ENET-S64 brain.
A BootP server for configuring the IP address of the SNAP Ethernet brains and the M4SENET-100 adapter card.
