SNAP-B3000-ENET
SNAP-B3000-ENET
OBSOLETE - SNAP Ethernet I/O Brain - Analog/Digital/Serial
*** This product is obsolete and no longer available.***
 Please consider the replacement parts SNAP-PAC-R1 and SNAP-RCK-M2B.
The SNAP-B3000-ENET Ethernet I/O brain is a compact I/O and communications processor that connects real-world analog, digital, and serial devices with Ethernet networks for monitoring, control, and data acquisition.
The brain can be used in an I/O unit as part of a SNAP PAC control system or in an independent I/O unit.
The SNAP-B3000-ENET is mounted on a SNAP B-series rack with up to 16 analog, digital, and serial SNAP I/O modules. The brain offers local intelligence for I/O features such as latching, high-speed counting,quadrature counters, thermocouple linearization, scaling, clamping, and 16 PID loops.
In addition to I/O features, the brain provides communication options including 10/100 Mbps Ethernet, PPP over a modem connection, Modbus/TCP, OPC, SNMP, and SMTP.
NOTE: Not all SNAP I/O modules are compatible with this brain. See Legacy and Current Product Comparison and Compatibility Charts to determine compatibility.
SNAP-B3000-ENET, SNAP-ENET-D64, and SNAP-ENET-RTC
Power Requirements
5.0 to 5.2 VDC at 1.0 A maximum (does not include module power requirements)
Operating Temperature
0 to 70 °C
Storage Temperature
-40 to 85 °C
Humidity
Network Interface
IEEE 802.3 network, 10Base-T and 100Base-TX
Serial Port
RS-232 (for modem connection using PPP; also for programming and maintenance)
Serial Data Rates
Default is 19,200 kBd; baud rate is soft-selectable from 2400 to 115,200 kBd.
100 meters with Category 5 or superior UTP.
Jumpers (Internal)
Boot to kernel/boot to loader; reset to factory defaults
Agency Approvals DFARS
SNAP Ethernet Brain Data Sheet
*** NOTE: These products are obsolete and no longer available.***
For new designs, you can use the SNAP-PAC-R1-B rack-mounted controller, which mounts on a B-series rack so you can keep your existing rack. The R1-B is substantially more powerful, can act as a controller as well as an I/O processor, and can communicate over a modem using PPP.***
With Opto 22's high-performance, flexible SNAP Ethernet brains (SNAP-B3000-ENET, SNAP-ENET-D64, SNAP-ENET-RTC) you can connect to state-of-the-art Opto 22 industrial I/O hardware using a standard TCP/IP Ethernet connection.
ioProject Readme Notes
SNAP Ethernet I/O Firmware README
This README file lists revision changes made to the SNAP Ethernet I/O firmware used in the following SNAP Ethernet brains:
SNAP Legacy Firmware README
This README file lists revision changes made to the firmware used in SNAP PAC family controllers before Version 8.0a, the SNAP-LCE controller, and SNAP Ultimate, Ethernet, and Simple brains.
If you are using SNAP PAC controllers and SNAP PAC brains only, use Form 1704, PAC Manager User's Guide instead of this guide.
Modbus/TCP Protocol Guide
In addition to groov I/O and the SNAP PAC System, the guide also covers Modbus/TCP communication with older Opto 22 Ethernet-based devices, including SNAP Ethernet, SNAP Simple, and SNAP Ultimate I/O; and E1 and E2 brain boards.
OptoMMP Protocol Guide
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
SNAP Ethernet-Based I/O Units User's Guide
*** NOTE: These products are obsolete and no longer available. For new development, we recommend groov RIO and groov EPIC. ***
This guide shows you how to install, use, and troubleshoot I/O units that contain the following brains: SNAP-B3000-ENET, SNAP-ENET-S64, SNAP-UP1-M64, SNAP-UP1-ADS, SNAP-ENET-RTC, SNAP-ENET-D64, and SNAP-UP1-D64.
NOTE: This guide replaces previous individual user's guides for SNAP Ultimate I/O (form #1311) and SNAP Ethernet I/O (form #1112).
ioManager User's Guide
ioManager is the software tool used to assign IP addresses and configure I/O points and system functions on most Opto 22 Ethernet-based hardware, including SNAP-LCE controllers: SNAP Ethernet, SNAP Ultimate, SNAP Simple, E1, and E2 I/O units; and SNAP-IT units. ioManager can also be used to directly read or write to these devices.
Case Study: Ballarat Health Services
Ballarat Health Services in Victoria, Australia, is a major health care organization comprising two hospitals, convalescent homes, psychiatric services, six nursing home hostels, and rehabilitation centers. Ballarat upgraded from older Opto 22 M4 controllers and now uses Opto 22's SNAP PAC System for equipment automation and building management. Their broad set of applications includes remote monitoring, alarming, process and discrete control, and data acquisition for performance optimization, energy management, and regulatory compliance reporting.
SNAP-RCK-B2M Rack Adapter Installation Note
*** NOTE:  These parts are obsolete and no longer available. *** Please contact Opto 22 Pre-Sales engineers to discuss options for your specific application.
This document shows you how to install the SNAP-RCK-B2M rack adapter. The adapter makes it possible to use a SNAP PAC rack or a SNAP M-series rack with a brain that would normally mount on a B-series rack (for example, the SNAP-UP1-ADS or the SNAP-B3000-ENET).
Case Study: Autostadt
This case study describes how Opto 22's SNAP Ethernet I/O helps to manage a German auto mall.
Technical Note: Using Offset and Gain
This technical note shows you how to set offset and gain for Opto 22 analog input modules.
Case Study: Grupo Antolin Gains Control of Its Headliner Assembly Process
Grupo Antolin uses sophisticated technology including robotics, scanners, "pick-to-light" bins, bar coding, inventory controls, and Opto 22 SNAP Ethernet I/O to manufacture and ship automobile headliners in the precise order needed by auto manufacturers such as Ford, Lincoln, Mercury, Chevrolet, and Pontiac.
Case Study: Callaway Drives Better After a Year with SNAP Ethernet I/O
In its new 225,000 square-foot manufacturing facility, Callaway Golf Ball Company used Opto 22 SNAP Ethernet I/O to increase its yield of golf balls from 33 to 99 percent.
Ethernet and TCP/IP for Industrial Automation
This white paper helps you to understand and evaluate how Ethernet and TCP/IP technologies are used for Industrial Automation.
SNAP-B3000-ENET Brain Firmware
This download contains current firmware for the SNAP-B3000-ENET brain.
AutoCAD Drawings
OptoAgent Integration (for CA Unicenter NSM 3.1)
OptoAgent Integration for CA Unicenter, in conjunction with Opto 22 SNMP-enabled Ethernet hardware, provides a convenient method for monitoring and managing real-world devices and business assets. OptoAgent allows for real-world data to be integrated into Unicenter.
The OptoAgent Integration supports both SNMP traps and polling to keep Unicenter updated on the current state of the hardware, and alert Unicenter of any problems. It also gives the user the ability to control the Opto 22 hardware.
OptoAgent Integration takes advantage of Unicenter Agent technology to graphically represent the Opto 22 hardware to the user. This Graphical User Interface (GUI) makes monitoring and managing real-world assets intuitive.
OptoAgent gives you the ability to read and write digital and analog I/O points that are attached to the Opto 22 hardware. These I/O points are connected to real-world electrical, mechanical, and electronic devices - such as lights, temperature and pressure sensors, motors, and serial devices. Using Unicenter, OptoAgent, and Opto 22 hardware, you can manage these real-world devices.
You can use ioManager software to configure the Opto 22 hardware and I/O points for use with OptoAgent. You can also configure OptoAgent to send SNMP traps based upon events you define.
Once the Opto 22 hardware and I/O points are configured, you can use OptoAgent View to see information about the Opto 22 hardware and the status and values of digital and analog I/O points.
SNAP Ethernet I/O BootP Server - Linux
A BootP server for configuring the IP address of the SNAP Ethernet brains and the M4SENET-100 adapter card.
