SNAP-AOV-25
SNAP-AOV-25
$378.00 (USA and Canada only)
SNAP 2-Ch 0-10 VDC Analog Voltage Output Module
The SNAP-AOV-25 provides two channels of analog voltage output at a nominal range of 0-10 volts. Each channel can supply +5 mA of load current. Although the two channels are not isolated from each other, the module is transformer isolated and optically isolated from other modules and devices. The module is factory calibrated.
Input
12-bit serial data
(each channel)
Outputs
0 to +10 Volts DC
Span
10 Volts
Resolution
2.44 mV
Response Time
(% of span/delta V/delta time)
99.9%/19.98 V/3 mS
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
250 V
Common Mode Resistance
>1,000 Megohms
Load Current (nominal)
5 mA (each channel)
Short Circuit Output Current Continu­ous
40 mA per channel
Accuracy
0.1% of Span
Gain Temperature Coefficient
50 PPM/°C
Offset Temperature Coefficient
20 PPM/°C
Isolation
1500 V
Power Requirements
5 Volts DC (±0.15) @ 150 mA
Ambient Temperature:
Storage
-20 °C to 70 °C
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
UL, CE, RoHS, DFARS; UKCA, NEBS
Lifetime
SNAP PAC System Product Guide
SNAP Analog Output Modules Data Sheet
SNAP I/O analog output modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for all SNAP analog output modules:
Case Study: University of California, Irvine
At the University of California, Irvine, Scientist Dr. John Garman and a team of his engineering students use an Opto 22 SNAP PAC System in their research of coal and biomass combustion. The SNAP PAC hardware controls the coal feed rate into an entrained flow reactor, monitors thermocouples that feed back process control data, monitors emissions, and acquires and logs data on operating conditions within the reactor.
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Video: Automation 101: Wire a Valve Actuator
Learn how you can wire a valve actuator to control amount of heating and cooling water flow in a HVAC system.
Accuracy vs Resolution
