SNAP-AIRATE
SNAP 2-Ch 0-25,000 Hz Analog Rate Input Module
Please call (800) 321-6786 to order.
SNAP-AIRATE
The SNAP-AIRATE provides two channels of frequency-to-digital conversion at 0-25,000 Hz. Nine volts through a 4.7 K Ohm pull-up resistor are provided internally for use with devices that have open collector outputs. The module works with TTL, CMOS, and open collector outputs and is ideally suited for use with a tachometer.
Also see the SNAP-AIRATE-HFi.
Nominal Input Range
0 to 25,000 Hz
Input Over-Range
To 27,500 Hz
Resolution
1 Hz
Input Response Time(% of span / delta Hz / delta time)
10.0% / 2,500 Hz / 0.1 sec
63.2% / 15.8 K Hz / 0.9 sec
99.0% / 24.75 K Hz / 4.2 sec
Data Freshness (Max)
126 ms
DC Common Mode Rejection
> -120 dB
AC Common Mode Rejection
> -120 dB at 60 Hz
250 V
Accuracy (% full scale)
±4 Hz or ±0.5% of the input fre­quency (whichever is greater)
Drift: Gain Temperature Coeffi­cient
200 ppm / °C
Drift: Offset Temperature Coef­ficient
50 ppm / °C
Input Coupling
Single-ended AC (capacitor coupled)
Input Amplitude
Sine wave
Square wave
2.5 V to 24 V p-p
0.5 V to 24 V p-p
Minimum Pulse Width
18 microseconds
Input Impedance (Inputs share the same reference point.)
Pull-up Voltage
Pull-up Resistor
50 K ohms AC coupled
(-input to +input)
6 to 9 V
4.7 K ohms
Isolation
1500 V
Power Requirements
5 VDC (±0.15 V) at 190 mA
Operating Temperature
-20 °C to 70 °C
Storage Temperature
-40 °C to 85 °C
Humidity
5-95%, non-condensing
Wire size
22 to 14 AWG
Torque, hold-down screws
4 in-lb (0.45 N-m)
Torque, connector screws
5.26 in-lb (0.6 N-m)
UL, FM, CE, RoHS, DFARS
Lifetime
SNAP PAC System Product Guide
This document lists and describes all Opto 22 SNAP PAC System part numbers, including PAC Project software, SNAP PAC controllers, SNAP PAC brains, and SNAP I/O modules of all kinds. SNAP PAC mounting racks and SNAP power supplies are also listed.
SNAP Analog Input Modules Data Sheet
SNAP I/O analog input modules are part of Opto 22's SNAP PAC System. This document includes descriptions, specifications, and wiring and dimensional diagrams for most analog input modules.
For analog modules with channel-to-channel isolation, see Form 1182,  Snap Isolated Analog Input Modules Data Sheet.
Opto 22 RoHS 2 Statement of Compliance - Restriction of Hazardous Substances
This document is a statement of compliance with the EU Directive 2011/65/EU, Restriction of Hazardous Substances (RoHS 2). This document lists Opto 22 products that comply with the substance restrictions of the RoHS2 directive.
FM Approval Document
CAD Drawing: SNAP I/O Module
Video: Securing SNAP Module
Video: Removing a SNAP Module
Demo: Accuracy vs Resolution
