$492.00 (USA and Canada only)
If you do not need loop sourcing, see SNAP-AIMA-i.
If you do not need channel-to-channel isolation, see SNAP-AIMA.
Input Range
0 to +20 mA with loop sourcing -20 mA to +20 mA
Maximum Over Range
± 10% (= ± 27500 counts)
Resolution
0.8 µA
Input Response Time (% of span/delta I/delta time)
99.9 %/19.9 mA/10 ms
Data Freshness
11 ms
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
36 mA or 9 VDC
250 V
Accuracy
0.05% (10 µA)
DRIFT: Gain Temperature Coefficient
30 PPM/ °C
DRIFT: Offset Temperature Coefficient
15 PPM/ °C
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Isolation: Channel to Channel
250 V continuous (1500 V transient)
Power Requirements
5 VDC (±0.15) @ 200 mA
Power Requirements - Loop Power (Input)
From separate field connector: 24 VDC nominal (70 mA max @ 24 V input, both loops @ 20 mA), 30 VDC maximum
Loop Power (Output)
24 VDC (± 1.5 V) @ 20 mA Open loop: 30 V maximum Shorted loop: 24 mA nominal
LED on top of module
Indicates that there is power to the 24v source supply 2-pin connector
Input Resistance
200 ohms (each channel)
Ambient Temperature: Operating Storage
-20 °C to 70 °C -40 °C to 85 °C
Humidity
5-95%, non-condensing
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
Wire size range
22 to 14 AWG
CE, RoHS, DFARS; UKCA
Lifetime
This document lists and describes all current Opto 22 SNAP PAC System part numbers, including PAC Project software, SNAP PAC controllers, and SNAP I/O modules of all kinds. SNAP PAC mounting racks and SNAP power supplies are also listed.
The isolated analog input modules described in this document are part of Opto 22's SNAP PAC System. They provide optical isolation, transformer isolation, and channel-to-channel isolation. This data sheet covers the following part numbers:
This CAD file contains a 3-dimensional drawing of SNAP-AIMA-iSRC, the SNAP 2-channel isolated -20 to +20 mA analog current input module with loop sourcing.
$104.00
