SNAP-AILC
SNAP-AILC
$405.00 (USA and Canada only)
SNAP Load Cell Input Module, 10 VDC Excitation, 2 or 3 mV/V Input Sensitivity
The SNAP-AILC input module works with 2 mV/V and 3 mV/V load cells as a load cell front end. Using a separate 24 VDC power source (purchased separately), the module provides isolated 10 VDC bridge excitation for up to four 350 ohm or 415 ohm load cells.
An LED on the module’s top indicates that 24 VDC are present at the top connector and that excitation is being provided to the load cell.
NOTE: In addtion to SNAP PAC brains and R-series controllers, this module also works with the following legacy brains, if they have firmware version R6.1c or newer: SNAP-B3000-ENET, SNAP-ENET-S64, SNAP-UP1-ADS, and SNAP-UP1-M64.
Also see the SNAP-AILC-2, which works with 3 mV/V and 4 mV/V load cells.
Input Range Sensitivity:
 SNAP-AILC
 SNAP-AILC-2
2 mV/V or 3 mV/V (Over range ± 2.2 mV or ± 3.3 mV)
3 mV/V or 4 mV/V (Over range ± 3.3 mV or ± 4.4 mV)
Input Resistance
100 Megohms differential
Resolution: Analog Scale Points
>22 bits + sign (± 6,400,000 counts = ± 100% of scale)
Response Time,
Data Freshness
See the following table
DC Reversal (Input)
0.015% (±1000 counts of reading @ 6,400,000 F.S.)
DC Common Mode Rejection
>-120 dB
AC Common Mode Rejection
>-120 dB @ 60 Hz
Maximum Survivable Input
± 15 volts across module load cell connector
250 V
Accuracy (% Full Scale):
 Offset
 Gain
± 0.05% (= 3,200 counts out of 6,400,000, out of box)
Usable Resolution at Default Configuration (Fast)
38 nV - sign and 19 bits (±524,288 counts @ channel 2)
At filter weight 64, settles to 99.9% of final reading in 3.9 s.
DRIFT:
 Gain
 Offset
40 PPM / °C
10 PPM / °C
Isolation: Optical
4000 V
Isolation: Transformer
1500 V
Rack Power Requirements
5.00 VDC to 5.20 VDC @ 120 mA
24V Bridge Supply:
 Input Voltage
 Input Current
 Output Fault Current
24 VDC nominal (22 V min. to 30 V max.)
40 mA for one load cell or 115 mA for four load cells
124 mA typical (field fault—shorted bridge)
Ambient Temperature:
 Storage
-20 to 70 °C
-40 to 85 °C
Humidity
5-95%, non-condensing
Wire size
22 to 14 AWG
Torque, hold-down screws
Torque, connector screws
5.22 in-lb (0.59 N-m)
CE, RoHS, DFARS
Lifetime
SNAP Load Cell Modules Data Sheet
The SNAP-AILC and SNAP-AILC-2 load cell input modules each provide one channel of transformer and optically isolated analog-to-digital conversion for load cell inputs. These modules also provide isolated 10 VDC bridge excitation for up to four 350 ohm load cells.
This data sheet includes descriptions, specifications, and wiring and dimensional diagrams.
SNAP PAC System Product Guide
Case Study: J.A. King
Whether it’s making sure grains are stored without excess moisture, weighing raw materials for chemical production, or batching and mixing ingredients for baked goods, automation is key to better results. System integrator J.A. King reduces costs for customers in a variety of material handling and mixing applications.
Video: Securing SNAP Module
Video: Removing a SNAP Module
Accuracy vs Resolution
