GRV-EPIC-BATT-BR2032-3
$17.00 (USA and Canada only)
groov EPIC PR1/PR2 battery, BR2032 Lithium Coin Cell, 3-pack
GRV-EPIC-BATT-BR2032-3 is a package of three replacement batteries for groov EPIC processors (GRV-EPIC-PR1 and GRV-EPIC-PR2).
For instructions about how to replace the battery, see the groov EPIC User's Guide (form 2267).
BATTERY LITHIUM COIN CELL BR2023 -30 to +80C 120 mAh 20mm x 3.2 MM
groov Accessories Data Sheet
groov accessories are additional or replacement parts designed specifically for the groov EPIC system. This data sheet covers items like groov I/O terminal connectors and cables that save you time and money when wiring field devices to groov RIO and groov I/O modules.
This user's guide shows you how to assemble, initialize, configure, and maintain a groov EPIC system and use groov EPIC processors, part numbers GRV-EPIC-PR1 and GRV-EPIC-PR2. The guide explains how to mount the power supplies, processor, and groov I/O modules onto the groov chassis, the first configuration steps to take after you turn it on, and how to keep the system up-to-date through system updates.
